Convertible top latch question
Old Apr 27, 2023 | 04:41 AM
A.O.'s Avatar
Default Convertible top latch question
So the passenger side latch on my 2005 seems a bit "loose"? It latches and unlatches just fine but it feels different than the driver side one. Mostly the little button you have to depress to actuate it needs a little wiggle to work sometimes. So is there an adjustment I can do or something else to get it tight again?
TIA
Old Apr 27, 2023 | 08:48 AM
Chuck S's Avatar
Maybe some clues here?
-- Chuck
Old Apr 27, 2023 | 08:57 AM
A.O.'s Avatar
Originally Posted by Chuck S
Thanks, although it is not making noise, the button just feels loose when detached. This makes it look like the latch is easy to remove (2 screws) so I think I'll remove it and do some investigating.
Old Apr 27, 2023 | 10:52 AM
A.O.'s Avatar
Ok, I went out to have a look, didn't need to remove the latches just needed to open them up and have a look. Both of those little buttons have a pair of screws holding them down, mine only had one screw on each side and they were backing out. So I removed them put a dab of blue Lock tight on each and tightened them up and now all is well. Now to track down a couple more screws and washers and put them on.
While I was out playing with the car I also changed out coil 1 and 2 and turned off the CEL. Went for a short ride but didn't re-trigger a CEL.
eagans2002
Jun 8, 2011 07:34 PM
captainbk
Jan 4, 2007 05:17 PM
owenxguo
Aug 25, 2004 10:12 PM
amongmany
Jul 29, 2003 06:08 AM
