Custom sig image generator
So after seeing all of db8's custom signature images (the small s2ks) I got inspired to create my own. Knowing of the troubles he had with them, I decided to go about it a slightly different way though. I created a bunch of custom sigs just for the local DelVal guys first, then cut/cropped/chopped/stitched everything together into a website that lets you choose a list of the parts you want. Parts will be added on an irregular basis (based solely on my boredom) and there is no guarantee that you part will EVER make it into the page.
Hope you like it.
Please only 1 version per car, I suggest using your s2ki screen name with an addition on the end if you have more than one car (username_2, username_track etc). If you link straight to the image provided, then when you come back to edit your sig, you can use the same screen name and it will automagically change in your sig as well as the gallery.
Thanks.
If you just want to play around with creating another sig and not messing up yours, then just don't enter a name in the name field and it will create the image to a temporary one that I use for testing additions.
New: If you go to the page, then click the link at the bottom of the parts list, it will open another page with all of the parts requests. Also at the top of that page is a field to enter a new part request. Please keep it reasonable and only add the parts you need right now to create a sig of your car(s). If the list gets out of hand then I may end up clearing it and putting a built in limitation of 1 part per day per person.
Sig Creator:
http://sigcreator.andrewjnuttall.com
Latest Parts:
Hope you like it.
Thanks.If you just want to play around with creating another sig and not messing up yours, then just don't enter a name in the name field and it will create the image to a temporary one that I use for testing additions.
Sig Creator:
Latest Parts:
I can do fully custom but will not agree to a specific time frame (could be a week, could be a year). However if you want you can also post up pics/lists of parts you want added so you can create your own.
Original Custom Sigs:
https://www.s2ki.com/forums/index.ph...&f=65&t=593644
Awesome little utility! Thanks for putting it together
I'm customizing my S. It's like TireRack's wheel chooser, only with more configurability!
We should all start posting up side images of S's so that assassin can figure out what's worth making or putting int.
I have an Amuse front lip, looks slightly more aggressive from side than OEM but I'll live with it...in a cartoon picture on teh Internets.
