Differential Fluid - Mobil 1
#21
I didn't have any diff whine with 75w-140 nor 75w-110. It was just that with the 75w-140, I got slightly worse gas mileage on daily drives.
#22
Anyone know what temperature the differential reaches in summer driving? I'd use my IR thermometer if I could but my rear diffuser is in the way.
From Torsen:
-- Chuck
From Torsen:
Essentially, the heavier, thicker, or more viscous that the oil is, the better it lubricates (generally). It leaves a heavier film adhered to the surfaces being lubricated. This reduces friction. But, that means that a differential operating in 75W-140 oil will have fractionally less locking effect than the same unit operating in 75W-90. This difference is not night and day – the changes are subtle. But if you’re fine-tuning a race car, it does offer one more knob that you can turn. By the same token, lubricant formulation and additives used have a similar bearing on the matter.
#23
Good Afternoon,
I've read a bunch of threads about what diff fluid to use, and I landed on Mobil 1 75-90 due to the availability of it. That being said, the only Mobil 1 75-90 I can find is the LS (limited slip) variant. Just making sure that it is safe to use this for my differential.
Thanks!
Thanks!
Get this one --> CASTROL SYNTRAX LONGLIFE 75W-140
#24
If it helps, i meassured about 70° C on the diff case after a run on the Autobahn, 220 Km/h + for more than 10 minutes. Oil in the diff was Castrol 75w-90.
But it was a very cold, drizzle night in October.
I will retry it and do a new meassure as soon as possible.
#25
