S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Talk (https://www.s2ki.com/forums/s2000-talk-1/)
-   -   Downshift Rev match (https://www.s2ki.com/forums/s2000-talk-1/downshift-rev-match-637055/)
lychyrychy Oct 2, 2008 04:13 PM
Downshift Rev match
Hi guys, :hello:
Just want to get everyone's experience on this real quick
I normall blip the throttle 1k rpm while rev matching from 6th to 5th, 5th to 4th, or 4th to 3rd. However, when revmatching from 3rd to 2nd, I actually need to blip harder, if that makes any sense, to rev match ... how about everyone else? I have a MY05 if that helps.
Terror Oct 2, 2008 04:55 PM
I think it has to do with the ratio of each gear. It is quite normal. I do it in my car all the time.
s2kvince Oct 2, 2008 07:09 PM
It's due to the gear ratio as stated above.
The larger the difference between the two ratios, the larger the difference in RPM will need to be.
1st gear - 3.133
2nd gear - 2.045
3rd gear - 1.481
4th gear - 1.161
5th gear - 0.942
6th gear - 0.763
roflitzjinno Oct 2, 2008 08:19 PM
yeah the ratios have to deal with it. the lower the gear youre shifting in its a higher rpm you have to rev to i think. when im going 30 in 3rd and downshifting to 2nd i have to rev to a bit above 4k.
white_turbo Oct 2, 2008 08:42 PM
you have to redline it if you go from 2nd to 1st.......
j/k.....
lychyrychy Oct 2, 2008 10:48 PM
Thanks for all the inputs :thumbup:
I thought it was weird at first.
hansai00 Oct 3, 2008 06:17 AM
Yeah it was like that my Prelude also. I was never able to do a smooth/fast rev match to 2nd gear. I feel like a lighter flywheel would take care of it.
hkspwrsche Oct 3, 2008 09:13 AM
you could double clutch if you have time
lychyrychy Oct 3, 2008 11:20 AM
^oh yeah! hmm good point.
ahrmike Oct 3, 2008 02:30 PM
i double clutch 2-3 shift, 3-2 shift, 5-6 shift and sometimes when its cold, 1-2 shift.
unless im having fun :D revving high seems to make the shifts go in easy.
© 2026 MH Sub I, LLC dba Internet Brands
