S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Talk (https://www.s2ki.com/forums/s2000-talk-1/)
-   -   Dropping the Hammer on the S2000 (https://www.s2ki.com/forums/s2000-talk-1/dropping-hammer-s2000-2440/)
WRS2K Dec 13, 2000 06:08 AM
If I get into a situation where I have to show a little S2000 love for all those who want a piece, is there a guideline on which gear I need to downshift to in order to get that instant punch? For any gear?
For example, let's say I'm cruising down the freeway at 65mph in 6th and suddenly, I have a need to pick up as much speed as I can at that very moment... being a new driver, I have no clue as to which gear I need to downshift to for maximum velocity.
How do you guys know if the downshift is going to hit the rev limiter? Is it just pure memorization of the car's engine response or is there a simple rule of thumb for downshifting fun?
[This message has been edited by SpaceNeedle (edited December 13, 2000).]
Fito Dec 13, 2000 06:11 AM
At 65 you should drop into 3th gear.
meat Dec 13, 2000 06:13 AM
Drive the car and figure out what speed 6000rpm is in each gear and what max speed is in each gear. Then you will know what gear to downshift to and when.
Pinky Dec 13, 2000 06:13 AM
It was a guessing game for a long time! I tried doing the 6-4 but that proved to be very hard! You could probably run in 3rd for a split second to get a nice jump at 65!
Much faster than that and you will be red lining before you know it and with minimal power. So at that speed a quick 5 and back to 4 move is a good way to go. Floating the stick into 4th from 6th is gonna be hard!
VA S2K Dec 13, 2000 06:31 AM
Drive the car in different gears at different speeds and get a good feel for what speed VTEC engages in each gear. Later it will come naturally as to what gear you should be in
3rd gear is good until around 93 mph, so either it or 4th would be good for accelerating away at 65 mph
pnty drpr Dec 13, 2000 06:34 AM
Try this.
These are the top speeds for each gear.
1st - 30mph
2nd - 60mph
3rd - 90mph
4th - 120mph
These are approximate, so don't rip me on this too much guys, but its what I've used to estimate the best gear to go into.
Basically, I know that if I'm doing 65, thats too fast for 2nd (it tops out at 60), so I pop it into 3rd.
If you're doing 95, for example, drop it into 4th (because 3rd tops out at around 90)
Go into the lowest gear you can based on the speed that you are traveling for that instant VTEC jump.
WRS2K Dec 13, 2000 06:54 AM
Panty Dropper,
Your post is giving me a good idea of what to expect. Thanks!
Why is going from 6th to 4th hard to do?
S2K-F8 Dec 13, 2000 07:03 AM
Originally posted by SpaceNeedle:
Why is going from 6th to 4th hard to do?[/B]
With the gears so close together, it's easy to slip and go from 6th to 2nd.
Low-S2000 Dec 13, 2000 07:18 AM
Only if you are shifting from the passenger seat :D
You will get the feel for this in time, just be careful until you do.
HopkintonMA Dec 13, 2000 07:19 AM
I have found the easiest way to go quickly from 6th to 4th is to briefly relax the shifter after disengaging 6th (because the natural hands-free point of the shifter rests at the 3-4 shift point), then just notch the shifter down into 4th.
© 2026 MH Sub I, LLC dba Internet Brands
