Fidanza flywheel
Fidanza flywheel
it's 8lbs. which i know is much lighter than stock, so i was wondering if anyone had any experience with it. once it's lighter it should be ok right?
http://www.evasivemotorsports.com/merchant...uct_Code=191581
8lbs is extremely light...
Originally Posted by overst33r,Aug 2 2007, 04:17 PM
What do you mean it should be ok? A lighter flywheel will let your engine rev up/down faster. You might gain some top end hp but lose some low-end torque...
Originally Posted by PeanutButter,Aug 2 2007, 04:25 PM
I have one in my car.
Only problem i have now is that it dips down to 200 rpms and shoots back to stock idle while coming to stoplights
Originally Posted by doublearon22,Aug 2 2007, 06:13 PM
The engine is not going to make and more or less HP or torque, nor will you loose any low end toque, lowering the weight of the flywheel allows the engine to more effectively transfer the power to the wheels. A very worthwhile mod, one that I have done to all my cars.
This M3 lost 1wtq and gained 12whp.
http://www.europeancarweb.com/projectcars/...l/photo_06.html
Originally Posted by nightcrawler7188,Aug 2 2007, 12:30 PM
does the car vibrate and rattle violently as well? or does the rpm just drop?
