Found this part hanging free inside my door - what is it?
So I have been trying to isolate a door noise for a while now. I finally took apart the door panel and examined inside between the door frames. I was expecting to find a lose nut or two. Instead I found this. It was just lying there on the base of the floor (between the outer metal frame and inside the back panel - see pics). What is this part? Any idea what the functional purpose is. How do I put it back? I would really appreciate it if someone could link a door assembly diagram where this part is pointed out. BTW aside from finding this part, everything seems to be working. The window goes up and down fine. PLEASE HELP!
where I found it lying
close up
inside panel
close up
inside panel
So I think I figured out that it is the "outer door handle protector" from the diagram below.
This is what mine looks like without the protector on there.
My question is, how important is it that I try to install it back on there (I might decide to have Honda dealer do it for me, since I haven't had luck with 3rd mechanics in my neighborhood). From what I am seeing on youtube DIY, it might be more complicated than I can handle.
I found this video for a dIY for exactly this great!
I am still not confident I can do it myself. How important is it that I put that back on there? HOw much might it cost in labor at the dealer? (I am in Tysons, NOVA area).
Ok. So I manned up and did it myself. It took 2hrs to do it (the stupid key cylinder would just not go back in). Anyways here is the after before and after pics side by side. I still have no idea how it fell off (or if it was ever on there to begin with). But this should definetly help solve my "harmonic rattle sound"...
Before
After
Hopefully this is helpful for someone else.
Before
After
Also I have to admit the car is super easy to work on too. I doubt I would be this brave with an older Porsche or BMW.
Received 1,555 Likes
Now that you are comfortable getting into door innards, you may want to apply some strips of B Quiet (or equivalent) to kill resonance and then add some lightweight hydrophobic sound insulation (3M Thinsulate anyone?) Reposition the plastic water barrier and panel.
You will be amazed at how much quieter the car is, how much better your speakers sound and what a nice "thunk" you get when you close the doors.
For now I think I have resolved most of the creaks, clanks and buzzing (Who knows how long that will last). I feel like in the summer the car calms down a bit (expanding plastics ???).
The resonance tiles won't block much sound, just annoying frequencies. The buzzy, resonating type sounds and frequencies.
If you wanted to quiet sound levels as well, you'd need to also add something like mlv over ccf or that lightweight 3M acoustic stuff.
kasher_khan (04-26-2017)
