Garrett Turbo F20C Swapped into a Triumph TR6
By Sarah Portia
Take the heart from an AP1 mix in some Mazda MX-5, a dash of RX-8, and the shell of a Triumph TR6 for taste.
By Sarah Portia
Is that a shell, or a chassis, or both.
If it is a TR6 chassis & you give it good grip, I would be very careful to build up to high performance around corners.
Great fun but not the most rigid of platforms, I think you might have to do a fair bit of stiffening & tuning, to work out some vicious response to throttle input at higher cornering forces. This is one project where I think slow in, fast out is likely to be EXACTLY THE WRONG technique.
I have a 330 BHP 4.5L Rover V8 powered TR8. Getting the power in there, getting a gearbox, diff, & limited slip centre to handle it was actually the easy part. I raced Formula ones, before they sprouted wings, so snappy handling was not exactly new to me either.
Curated Content Editor (08-17-2018)
We can expect S2000 engines going into different cars as more cars are totaled. More work than I'd attempt, but not a fan of this. The TR6 is a styling retrograde step after the T4/TR5/TR250 (Michelotti > Karmann), and 2491 curb weight before they added enough fiberglass to build a boat.
I've been seeing a TV commercial a lot recently featuring an MGA. One of those would be a more elegant starting point, if the motor would fit. IMHO, YMMV, etc.
This one here is interesting in how the F engine was taken out only to be replaced by a V6 from the NSX. All in the Family engine swap: NSX-Powered S2000 | DrivingEnthusiast.net
