S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Talk (https://www.s2ki.com/forums/s2000-talk-1/)
-   -   Key Fob replacement (https://www.s2ki.com/forums/s2000-talk-1/key-fob-replacement-667402/)
rotorman7 Jan 29, 2009 01:20 PM
thanks guys its been a pain in the butt for the past couple of months to have to manually lock and unlock the car with the key and reaching over for the passenger door cause i bought the car without the fob andjust cant take it anymore
thanks Jeremy
shotiable Jan 29, 2009 01:55 PM
Originally Posted by NoRawkus305' date='Jan 29 2009, 09:25 AM
Here is a post I copied the instructions from. It is stated for the OEM keyless entry remote. I don't know if it is the same for the OEM keyless entry with alarm. Now this post was by xviper, so I am positive this should work. If you don't know who viper is, he is the know it all of know it all with the S. Enjoy.
xviper -
Our receiver can store up to 3 remotes. If you try to put in a 4th, the first one that was ever programmed will be "kicked out".
From the Helm manual, p. 22-134:
Does the LED on the transmitter come on when you press a button? If not, the remote is faulty.
Press the lock or unlock button 5-6 times to reset the transmitter.
If the locks still don't work, did you get the remote wet? If so, replace - it's toast.
Battery OK?
You probably know this but just in case:
To program:
Close doors, hood, trunk.
1. Ignition ON.
2. Within 1-4 secs. push lock or unlock while aiming the remote at the receiver.
3. Within 1-4 secs, turn OFF ignition.
4. Within 1-4 secs, turn ON ign.
5. Within 1-4 secs, repeat (2.)
6. Within 1-4 secs, turn OFF ign.
7. Within 4 secs, turn ON ign.
8. Within 1-4 secs, repeat (2.)
9. Within 1-4 secs, turn OFF ign.
10. Within 4 secs, turn ON ign.
11. Within 1-4 secs, repeat (2.)
12. Confirm that you hear the door lock actuators. Within 1-4 secs, push the transmitter lock or unlock button again. The keyless receiver is now in the program mode. You must push the transmitter lock or unlock button of the first transmitter again to program that remote.
13. Within 10 secs, aim the transmitters (up to three) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn ign. OFF, and pull out the key.
15. Confirm the operation of the new codes.
16. I need a ciguarette!
kudos to people who actually answer questions instead of saying search :hello: searching is difficult unless you've done it quite a number of times here
and definitely don't go to the dealership, they'll rip you off
driftintherain Jan 29, 2009 05:13 PM
what is the difference between B-stock Remote and Programming and the regular remote and programming
AJ_72 Jan 30, 2009 06:20 AM
The b stock looks to be refurbished and the "regular" is new. Regardless, the programming would be the same.
© 2026 MH Sub I, LLC dba Internet Brands
