Losing control!
Old Nov 3, 2005 | 02:49 PM
  #21
JLEEzAP2's Avatar
Smile
hmm.. tires arent on warantee right? Hmm went to america's tire co... they took apart my tire and it was torn in the inside and had a nail in it. they gave me a replacement until i get a new tire. the tire is almost the same size but its about 235... the problem is still there!!!!!!! wtf! i cant drive it anywhere.. what the hell is going on!??!?
EDIT: wow i did not know bridgestone s02 on the rears would cost 280 dollars each!
Old Nov 3, 2005 | 03:02 PM
  #22
beantown's Avatar
i had a nail in my driver side rear tire, same thing happened to me as the handling sucked ass. when i checked it the psi was at 10
Old Nov 3, 2005 | 03:08 PM
  #23
JLEEzAP2's Avatar
what tires are equivalent to bridgestone s02's?
Old Nov 3, 2005 | 03:22 PM
  #24
brent_strong's Avatar
Replace it with an S02 or replace all 4. Mismatching tires would likely mean a wreck for you. It would be ESPECIALLY bad to mismatch rear tires, nearly as bad to mismatch both front vs both rear.
Honestly, if you can't put up $280 (I think you can find them cheaper though) for maintenance on the car, you're probably in over your head and should look into something cheaper.
Old Nov 3, 2005 | 03:31 PM
  #25
44Runner's Avatar
it is fine to use different tire on the front then the rear, but DEFINATELY don't put a different tire on one side of the rear then the other side. That is a big no no and will likely lead to a continuation of your current problem and premature wear on your LSD...
Look around for a better price, that sounds pretty steep to me. I would think it should cost around 200 for that tire but honestly don't know for sure. And make sure it is the right kind of S02. Yes, there are different kinds.
Do yourself a favor and give Jim @ Tirerack a call. He will give you a reasonable price and make sure you get exactly what you need. Jim is a good guy and a lot of us S2000 owners buy through him.
www.tirerack.com
EDIT: Tirerack has the rear tires listed at $177 each
Old Nov 3, 2005 | 03:39 PM
  #26
slasherx's Avatar
What should be the tire pressure for the respective tires?
Old Nov 3, 2005 | 04:15 PM
  #27
Saki GT's Avatar
Tires are the most expensive thing on the S. Flats suck, but hazard warranties will protect the tire. The trade off is between an $$$ tire to begin with, and short tire life (11-17k mi).
With 6k miles on you old tire, you are really at the point where you need to get a new rear set.
Old Nov 3, 2005 | 06:52 PM
  #28
jyeung528's Avatar
Originally Posted by Paul55100,Nov 3 2005, 09:38 AM
Dude! A tire guage is $2!!! Go get one!
i would not buy a $2 tire gauge.
My $15 tire gauge was off by 7 psi.
  #29
jyeung528's Avatar
Get Longacre.
Old Nov 4, 2005 | 10:42 AM
  #30
JLEEzAP2's Avatar
how long does tirerack take ?
