S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Talk (https://www.s2ki.com/forums/s2000-talk-1/)
-   -   Moisture in headlight (https://www.s2ki.com/forums/s2000-talk-1/moisture-headlight-599466/)
darkwatch May 25, 2008 06:25 PM
So we have been getting alot of abnormal rain around here which has resulted in alot of moisture build up in my pass. headlight and i was just wondering if there was any way to get the moisture out and prevent it from happening again?
negcamber May 25, 2008 07:02 PM
Pull the bulb and let it dry out. Don't go too long with water in there...it will pool down at the ballast and cause it to corrode and blow.
darkwatch May 26, 2008 10:17 AM
how do i go about doign this
vtec4life May 26, 2008 10:24 AM
Alot of people may not like this solution but I think it will work, when I use to own an integra over on their forums some people drilled a small hole on the bottom of the hosing allowing water to get out and air tor dry but no water to get it, cause how will water climb upwards? you can try that.
darkwatch May 26, 2008 05:35 PM
i dont like the idea of drilling holes in the very expensive headlights...
Olegator May 27, 2008 08:14 AM
take the headlights out and reseal them....the reason you get the water in the firs place is because there is a small crack somewhere in the area where two plastics meet.
darkwatch May 27, 2008 03:47 PM
so then basicly i take the head light out and smear silicone all around were the lense meets the back and it will solve my problem?
Olegator May 27, 2008 07:54 PM
It should...
I used the soldering iron and went around the whole lens and "re welded" it
Then I dried the moisture out, after that I did not have any problems
Vi37573r May 27, 2008 08:47 PM
When I got moisture in my headlights I also resealed them. Did it a different way though. I removed them and baked them to remove all of the old sealant then resealed it with high temp silicone. Solved my problems but was kinda difficult, especially when the headlight was burning hot.
You can find the instructions how to remove and bake the headlight assembly here.
http://ricks2k.com/info/instructions/diffuser.pdf
Rickjames May 28, 2008 10:16 AM
Taking apart and resealing the headlights is a pain in the neck. I bought a used housing from a local junk yard and it has been perfect--only $100. Resealing is cheaper, but honestly, if you don't do it right it will look terrible.
© 2026 MH Sub I, LLC dba Internet Brands
