my s slides hard going from 1st go 2nd - ?problem
i have a basically stock s and i have notice lately that i get a pretty major slide only to the right(3-6ft.) when shifting hard from 1st to 2nd, my tires are the stock s02s and still have decent tread left (35%), i never noticed this when the car was newer, does anyone else experience this. One time I felt like I was heading for a 180?
Lol its cause your shifting hard and right. That happened to me when i drove my frineds 99 stang gt, the ass went out like 3 feet, quite a scary feeling the first few times. I did not think the s2k could do it, but who knows. Mike
[QUOTE]Originally posted by osu s2k
[B]i have a basically stock s and i have notice lately that i get a pretty major slide only to the right(3-6ft.) when shifting hard from 1st to 2nd, my tires are the stock s02s and still have decent tread left (35%),
I'd say adust your technique a bit. It would probably be a good idea to "feed " the throttle as you let the clutch go, and not like an "on/off" switch. This doesn't mean do it slower, just smoother.
I would assume that this happens when you make the 1-2 shift while making a turn (left more likely than right). Am I correct?
I have encountered the same situation many times and my tires have been warm, tire pressure fine (37/35 psi), and I don't have any spring spacers.
The reason for this behavior is because the S2000 exhibits a bit of lift-throttle oversteer. If you stay on the gas and hold a gear through a turn, the rear end stays planted very well. However, if you lift off of the throttle quickly to change gears while in a turn, the rear end will significantly lighten up and feel like it's stepping out. When you get back on the gas, in the new, gear, the rear end will plant itself again.
Conclusion: it's poor technique to shift and accelerate hard while in a turn. You can too easily unsettle the balance of the car.
P.S. I've also had the rear step out, to the right while going from 1st to 2nd, quite a bit while accelerating hard in a straight line. Normally, my tires would just chirp going into 2nd but I attributed this incident to my tires being very worn (at the wear bars with 18K miles on them).
Originally posted by speeeding
There's nothing wrong w/ shifting, and accelerating while turning.
Actually, I'd love to try a shifter kart someday. It looks like a lot of fun and a fairly inexpensive way to get into true racing (if there ever was an inexpensive way to get into racing). By "true racing" I mean a vehicle that was built for that purpose.
