Need backup key and remote
Bought an 02 from private seller about a month ago with 1 key and 1 remote. I probably should get an extra set of keys and remote cause you never know.
Should i go to dealer? Suggestions?
For the key you will need to go to dealer. For the remote, can you describe it? (Number of buttons, shape, etc?) If it is just the standard Honda Keyless entry fob, then you can get one for cheap off of eBay.
The problem with the key is that there is a microchip in the key that is coded to the computer in the car. You need the dealership to set the code on the key for you.
Ok guys yes each key has an imobiler chip in it that will link up to your ecu so that you can start the car - thefeore the dealer is the only one that can help with the key
as for the remote - It's very easy to program once you get an extra one
http://www.handaaccessories.com/crv/KEYLESSPROG.pdf
you can have up to three remotes for each car..
if any of you are intrested i can sell you my spare one for $25.00
I found the link to the JDM Key thread:
http://forums.s2ki.com/forums/showthread.p...ghlight=JDM+Key
Here is the imobalizer chip:
