need help from someone with helm's manual
i'm attempting to replace the windshield frame tape. if someone could kindly scan the section on how to replace the windshield i'd surely appreciate it. i'm planning on documenting the entire process, with pics, in case anyone else is interested. right now i can't seem to take off the rubber part around the front of the windshield, it appears that the windshield is wedged inbetween it.
if anyone can help, many many thanks in advance.
sihuor
sihuor
That is becasue it is. I really don't think you can do it with replacing the windshield at the same time.
As you can see from the pic below, it is thick. It is glued inplace with some heavy duty silicon sealer. To remove it, the windshield tech cuts it from under side, to seperate the seal halfs.
