Performance on S2000's
Hi there, wondering if some experts can share some views.
My S2000 is approaching 100k soon, i have always wondered with a car with 100k
+ miles does the performance suffer? eg a s2000 for example with 30k compared to a 100k one. I presume with bore wear and valve clearance is does.
thanks
thanks
https://www.s2ki.com/forums/index.php?showt...5&#entry1680654
this could give u an idea, at the least do a compression check. A nicely taken care of s2k will go a long ways. There will be normal wear and tear, but thats normal.
When I traded mine in for an NSX I had 100,022 miles on it and it was as good if not better feeling to me. Plus the re-sale value was top notch. Hondas go and go for a long time. I have had 13 of them and not one them ever failed me...
Originally Posted by iam7head,Jun 25 2006, 06:36 PM
Compression and leakdown test would be your first step
mine was well within spec with 95k on the ticker
Thanks for your reply so far.
Originally Posted by admanirv123,Jun 25 2006, 10:53 AM
How would i perform this checks, and why are the neccesary.
good example:
cylinder 1 200
cylinder 2 195
cylinder 3 195
cylinder 4 200
bad example:
cylinder 1 200
cylinder 2 100
cylinder 3 195
cylinder 4 200
cylinder 2 lost compression might due to bent valve, bad ring and lot more stuff.
a leakdown test is similar to compression test but it's way more infomative about the car.
the leakdown test pressureize the cylinder and see if the cylinder can hold the pressure for a period of time. A slight down of pressure is normal but anything over 5 percent you might have a problem.
for example:
good example:
cylinder 1 clocked in for 200psi compression and after five minute, it dropped to 195 psi, that's within the magical 5 percent margin.
bad example:
cylinder 1 clocked in for 200 psi and dropped to 150 psi in the first minute, that could indicat a leak somewhere(you can trace the air leak by using a tool, you can listen to exhaust valve or intake valve and it will tell you where is the leak coming from.)
it's pointless to dump alot of money into a dying motor, so test the water before jumping into it
to answer you second part of the question, you will need a compression guage and leakdown tester.
i have both at home, i work on cars way too much to be without those babies, if y ou need detail instruction let me know.(ASE classes
I was wondering this too. I have a long way to go, but since I daily drive mine to college I was concerned that a few years it may not perform as well due to the normal wear and tear that comes with high-mileage. I guess that's always an excuse to build a motor
