presistant odb2 code: P1457
P1457 ????
thanks |
looks like leak in the evap system... is your gas cap tightened all the way down?
A loose gas cap WILL NOT set a P1456.
The 1457 is a evap leak on the canister side of the Evap system. The most common cause for this DTC in climates that have snow is a rusted/corroded EVAP bypass solenoid. It really needs to be checked out by a qualified and experienced Tech to properly dianose this system. |
The 1457 is a evap leak on the canister side of the Evap system. The most common cause for this DTC in climates that have snow is a rusted/corroded EVAP bypass solenoid. It really needs to be checked out by a qualified and experienced Tech to properly dianose this system. P1457: got this about a mo ago, been ridng the bike tho till today's rain. the err code did not go away on its own, it stayed up a long time till a manual clr today. good to get rid of the err, will not have fun in the safe mode. probable cause = EVAP canister & the related system of hoses & valves bad? any idea of most porbable things to ck. alot of posts to the effect the valve on top of the canaster not working. |
| All times are GMT -8. The time now is 11:59 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
