Problems with s2k
Old Aug 26, 2003 | 02:38 PM
shakeb0x's Avatar
Default Problems with s2k
Good afternoon,
I noticed with my s2k that after i shift into 2nd, 3rd, or 4th gear. I would hear a rattling noise. If I would press the gas pedal, the noise would go away? Any advice on this. I've been told that the clutch may need a change very soon. Also , when I am in 2nd or 4th gear, the shifter would pop out of gear and go to neutral. If anyone has seen problems like these, please inform me on the proper way to repair this. Thank you
Old Aug 26, 2003 | 02:51 PM
HI SPEEDR's Avatar
I suggest that you bring your S into your Honda dealer for the fix. It could be some small thing.
Old Aug 26, 2003 | 03:11 PM
Austblue's Avatar
Sounds like some of the TSB symptoms you can find the links to the bulletins in the library on this site.
ps I suggest that you change your sig before anyone else pics up on it. Its called silverstone not gunmetal
Old Nov 18, 2003 | 09:03 PM
TonyY510's Avatar
can anyone tell me wahts a TSB
Old Nov 18, 2003 | 09:09 PM
3ngin33r1's Avatar
Old Nov 18, 2003 | 09:52 PM
Stratocaster's Avatar
Technical Service Bulletin
Old Nov 19, 2003 | 07:23 PM
TonyY510's Avatar
would that be covered with a warrenty???
have any of u guys done it free of charge???
Old Nov 19, 2003 | 07:55 PM
DarioManfretti's Avatar
TSB are like a recall and should be covered at no charge.
Old Nov 19, 2003 | 07:57 PM
3ngin33r1's Avatar
not if you're out of warranty.
Old Nov 19, 2003 | 08:03 PM
That depends is you are under warranty. Sometimes is can be done when you are outside of warranty as a "good will" fix. But that is up to the DSM (District Service Manager).
All a TSB really is a fix (part and/or procedure) to a problem. They are meant to save the Honda Techs time to solving some issues. Lets take the clutch decel buzz issue. Many tech may not have every heard it before , so knowing that AHM had found this issues to be a clutch, they updated the part used at the factory. This updated part could then be used if a customer had the same problem.
That is the short version, I am sure there is more to it, but you get the idea.
