rear end
I want to know how I can flush out my rear end.i draind it the other day and it was black. I put in Honda rear end oil.but I would like to flush it out until the oil runs clear.
If you are really wanting a "flush" just change the diff fluid really often.
Change it, drive it 500 miles, change it, drive it again 500 miles, Change it, repeat the cycle until you are happy with the result. This will not be super cheap though. Any idea how since the last change was done? |
Originally Posted by Neilwf
(Post 24607754)
I don't think Honda has gear lube for the S anymore. If its the 75/85 I'd get it out of there fast. A lot on here go with 75/110 or 75/140 gear lube. Honda does make a 90w for outboard motors, don't think I'd use the either.
Do a search and you will find a lot on gear lube Rod |
thanks guys.i did get Honda rear differential oil.but if there is better oil to use please let me know
Search is your friend. Tons of threads here on this.
Originally Posted by rpg51
(Post 24607833)
https://cimg6.ibsrv.net/gimg/www.s2k...71b05dff1b.png
You can't go wrong with this one. It is about $16. One of the well known S2000 mechanics, a moderator on this site, has stated his confidence in this particular diff lubricant. |
