Recommendation for windshield wipers?
I know this might be silly to ask as many of you only drive in fair weather, but my wiper blades are shot.
Anyone have a recommendation of what brand to use (perhaps even know the size of the S2000 wiper blades off hand).
Or is it best to just go to Honda and pay some silly amount for OEM blades?
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
Former Sponsor
If the part number equals the length, the passenger side is 20 inches, and the driver's side is 16 inches. I just purchased a set of Bosch Micro Edge Excel wiper blades. Part numbers; Driver's side- 40916, Passenger's side -40920. I used these blades in my '97 Prelude for three years with good results.
One caveat to the great wiper action (and it is quite good) is that this type of wiper blade uses a little softer rubber than usual so they wear a little faster. I found the streak free windshield after each sweep worth the slightly more frequent replacement.
James
James
James,
Thanks! I did measure and get those same results of 16 and 20. 20 isnt too odd, but 16 is downright tiny! The last car I replaced wipers on had 20 and 22.
I'm guessing the refills are of the narrow variety?
Silver Surfer,
thanks for the info on the metal strip. I never toss those until the new set is in, but thanks for the reminder...
Silver Surfer,
I agree. Bosch wiper blades are second to none. I have already replaced my '00 Accord blades with Bosch blades after 4K miles. The OEM blades used to leave a lot of gummy residue.
The Bosch blades are great but they leave graphite residue behind. Despite cleaning you may see a subtle arc on your windshield after a while. No harm done but you may have to clean the glass more often.
I've tried different brands of blades but always went back to the OEM blades from Honda. You need to replace them more often, I do it every 8-12 months. The refills are only about 3 bucks each which may be a little higher than aftermarket but it's worth it.
I live in the South so your experiences may be different if you live in the cold regions.
Honda uses a very good grade of rubber and they never skip or make noise.
BTW, I don't recommend RainX. While it does a good job of improving visibility, it does a number on the blades.
