Redlining
i was wondering what is the MPH at each gear at redline???
thanks |
According to Road and Track:
1st - 42 2nd - 64 3rd - 89 4th - 114 5th - 136 6th - 150 My experience is that these numbers from 1st thru 4th is pretty close, maybe slightly low, but close. |
The 150 in sixth isn't redline, only R&T's approximated top speed, which is a bit lower than the actual flat-ground top speed.
There's a couple hundred RPM difference between redline and the rev limiter, so in each gear you can actually go a few mph faster- (about) 45, 66, 93, 118, 141, 175 - for the sixth gear run to redline check out Turbo Dave's video in the s2ki library... Originally posted by S2WOOOW According to Road and Track: 1st - 42 2nd - 64 3rd - 89 4th - 114 5th - 136 6th - 150 My experience is that these numbers from 1st thru 4th is pretty close, maybe slightly low, but close. |
At 9000 rpm:
43.2 65.7 90.9 116.1 139.5 166.5 |
I really enjoy bouncing off my rev limiter at 7,200 rpm.
(Current mileage... 209,000 miles) :D |
| All times are GMT -8. The time now is 04:18 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
