Ringing sound when let off the gas
My '01 w/2600 miles started making a quiet ringing sound. When I let
go of the gas pedal I hear this sound almost like a quiet cell phone ringing. Any one experience this?? |
I should add that this sound just started happening.
[QUOTE]Originally posted by alphaman
[B]My '01 w/2600 miles started making a quiet ringing sound. |
THat's a bout the right mileage for it to start happening - however, I would suggest living with it for as long as you can and get the new clutch later.
Does it "ring" while decelerating in 3rd gear at around 36-40 MPH? That's my clutch buzz.
It some cars it comes across as a buzz and others as a ring.
It really depends on how you set the ring type switch to :) |
It's the clutch. It's a problem that won't go away so you'll need to learn to live with it. The clutch TSB doesn't solve it.
Originally posted by s2ktaxi THat's a bout the right mileage for it to start happening - however, I would suggest living with it for as long as you can and get the new clutch later. ...ramble, ramble....oops, sorry about that...back to the point :D... How long is a TSB good for??? Thanks in advance. |
The TSB is good till you actually use it - ideally before the car is old and rusty... You should be able to do it up to 36k miles. If you want to be on the safe side, just mention it the next time you have your car at the dealer but tell them to not do anything yet because you don't have the time. That way, it's doc'd earlier. Then you can come "collect" later.
