S2000 cutting out
Old 12-05-2018, 10:57 AM
Thomas1986's Avatar
Default S2000 cutting out
Hi folks new to this thot ad give it a bash my Honda went into a limp mode the other day and wen a got computer on it says fault was oil sensor or something so a checked oil and put code out stil no vtec coming in and wen a put clutch in wen driving it engine cut out any idea plz as am a plumber no to clued up on fixing
Old 12-05-2018, 01:28 PM
Car Analogy's Avatar
Received 1,315 Likes on 993 Posts
Apparently not a fan of punctuation either...
Its difficult to yell what you mean. I'll assume you are trying to say that the engine runs normally for general driving, but whenever you try and engage vtec, it 'cuts out', in the sense that vtec does not occur. The power is simply not there.
That combined with the oil related trouble code has me thinking its a clogged vtec screen. An easy fix for someone with decent diy skills.
You remove vtec solenoid, clean the wire mesh screen, reassemble.
I would suggest finding someone local to help you with this...
This may not be the issue, but its easy to do and seems to align with your symptoms. So try this first.
Old 12-05-2018, 10:27 PM
Thomas1986's Avatar
No getting vtech at all mate and wen driving normal
and press down on clutch the car just cuts outs
and ignition lights come on
Old 12-05-2018, 10:28 PM
Thomas1986's Avatar
And thanks folks for giving me advice
Old 01-24-2019, 08:11 AM
minubaba's Avatar
Check your MAP sensor. It might not have failed completely, but on it's way out. Also, clean the MAP tunnel, small hole it reads from. I think they cost less than $150.
Old 01-31-2019, 09:39 PM
jyeung528's Avatar
what was the fault code?
maybe related to your idle air control
Old 01-31-2019, 10:08 PM
s2000Junky's Avatar
Doesn't sound good. Did you run the oil real low?
Thomas1986
12-14-2018 08:13 AM
KINGCOBRA
02-14-2016 01:53 AM
nicholasbartleet
10-17-2009 11:47 AM
brunodkid99
06-09-2007 07:03 AM
ggarriso
08-02-2005 01:28 PM
Quick Reply: S2000 cutting out
