So apparently I drive like a Grandpa
Everybody talks about how tail happy the s2000 is, but I've never had a problem. I've never broken the rear out accidentally at all.
What is wrong with me?
Actually
04-07, least likely to kill you
00-01, most likely to kill you.
AP1 [00-01]: 218 (3.9 kg/mm) 291 (5.2 kg/mm) ( Published )
AP1 [02-03]: 249 (4.4 kg/mm) 306 (5.46 kg/mm) (From SCC, also note that the UK Press release stated firmer springs )
AP2 [04-07]: 266 (4.75 kg/mm) 275 (4.91 kg/mm) ( 7% stiffer Fr, 10% lower Rr, compared to prev)
AP2 [08 --]: 284 (5.07 kg/mm) 299 (5.33 kg/mm) ( 7% stiffer Fr, 9% Stiffer Rr, compared to prev)
CR [08 --]: 389 (7 kg/mm) 349 (6.25 kg/mm) ( 37% Stiffer Fr, 17% Stiffer Rr, compared to prev)
You must be a careful and responsible driver.
Next time it rains, go into an empty parking lot. Turn off VSA (if you have one). And the hit the gas. The rear WILL break loose and dance around you...
On dry pavement, if you try to take a sharp corner above 45mph, the rear and is very likely to break loose. Who in the right mind would do this? I don't know. But it happened to me once (don't ask) and VSA put me back in line.
