spark plug TSB is now a recall
my dealer performed the spark plug TSB and indicated that it is now a recall...
they now replace the plugs with a different size plug. i dont have the old plug info anymore (they covered it up in my manuals with the new info- with stickers), but the new ones are: NGK PFR7G-11S or DENSO PK22PR-L11S does anyone know enough about spark plugs to recognize the diff between these and the ones that came with the car? i wonder why they had to change... |
I assume this only for OEM plugs right? If we replaced the OEM plugs with different ones we don't need this fix?
Originally posted by S2K Power I assume this only for OEM plugs right? If we replaced the OEM plugs with different ones we don't need this fix? i would guess that you do need to change them, since they were put in to replace the old size plugs, and the plug size (?) has changed- i see that the new plugs have a different torque pressure than the old ones... i assume that you need to make sure that your plugs are compatible with the new ones indicated in my previous post. |
Just got my recall notice today. The notice says it has to deal with the spark plug gasket. Original part number was: NGK PFR7G-11. The "S" means stailess gasket (per NGK data). . The recall says there is a possibility the engine light may come on due to misfire....guess they don't want to mention you can blow your motor ;).
Utah |
interesting utah...
they change the plugs and even make us chage the owners manual to reflect the correct plugs (new size). i know that the TSB said it was for gaskets, so its interesting that they are also changing the plugs! |
Well this is exciting. The only other recall was for the seatbelt.:p :p :LOL:
i think they decided on changing the plugs all together with teh gasket ring to minimize future issues. i am sure its not that much more of a cost issue to just take care of it now, vs having to deal with bad plugs later.
I would think that those who already changed the OEM plugs with something else only need check the torque setting used (18# vs the 13# listed in the manual) |
[QUOTE]Originally posted by wanabe
[B]my dealer performed the spark plug TSB and indicated that it is now a recall... |
That DENSO plug is PK22PR-L11. Let me not add to confusion by my bad typing.
Originally posted by Utah S2K Just got my recall notice today. The notice says it has to deal with the spark plug gasket. Original part number was: NGK PFR7G-11. The "S" means stailess gasket (per NGK data). . The recall says there is a possibility the engine light may come on due to misfire....guess they don't want to mention you can blow your motor ;). Utah Ignore my posting. Thank you, Utah S2K. I think I took 2 Stupid Pills rather than 1 first thing this morning. |
