Stall-like shake when clutch is depressed
When I am driving, let's say 10 mph in 1st gear, and I press the clutch when I am going to a full stop, right as a press the clutch, the revs drop too low, to below the idle speed, and the car has this "almost stall-like shake". This happens occasionally whenI depress the clutch for more than an instant, regardless of the gear I'm in. It feels like the car is about to stall, but right when the revs dip down it goes back up to normal. So the "shake" only lasts for about a second. I took my car to the dealership, and the guy said I might need a new clutch within the next 1000 miles or something.
Is this true? Should I be concerned? Has this happened to anyone else?
(I drive a 20002 with 24,000 miles and it's on its first clutch. I drive the car like a baby, so I couldn't have ruined the clutch in this amount of time, so if it does need to be replaced, it must have been the previous owner.)
[QUOTE]I had this problem also. I think when I adjusted my valves the problem went away.
I also had the valves adjusted two months ago and it fixed it for a while and now the problem is back.
If you were to look for these symptoms in the "Under the Hood" section, you would discover that in fact the problem lies within your ECU. Your car is constantly teaching itself how to adapt to its environment, and as the environment changes (ie. Season, location, weather, anything) so do your car's needs.
If you are having this problem consistantly, you might need some new electronic components but there are two things that have the highest correlation with what you are experiencing: The MAP sensor and the ECU. Neither of them are broken, but you might want to give the MAP sensor a Whack (see: MAP Whack in the search).
As many have suggested, don't give your car more gas when you think it's about to die. This just "confuses" the ECU, which is trying to learn how to deal with the environmental change.
Let me guess: Has it been hot(ter) outside lately? Have you been running the air conditioning? You have nothing to worry about, and you definitely don't need a new clutch.
Check out more information Under the Hood.
