Starting After Storage
Old Dec 22, 2025 | 07:41 AM
pnbcoolbreeze's Avatar
Default Starting After Storage
Is there a way to start the S2000 without it firing after a prolonged winter storage?
Old Dec 22, 2025 | 08:04 AM
windhund116's Avatar
Pull the spark plugs. This also reduces the initial compression pressure. Crank until the oil pressure symbol's light goes off.
Good luck!
Old Dec 22, 2025 | 09:31 AM
Stoatmaster's Avatar
How long has it been stored?
If we are talking years, then as above, building up oil pressure is a good thing before actually running the engine.
If we are just talking over the winter period, it's a modern engine with modern oil, (Plus it's a Honda), so I'd just run her up. (Mine sits for 4-5 months over winter on a trickle charger) Gets fired up, then I drop the oil and she good for the summer.
Old Dec 22, 2025 | 04:20 PM
Car Analogy's Avatar
Yeah, I wouldn't pull plugs every year. More could go wrong vs tiny benefit. Sure,if it was unusually long rest, why not. But not routine storage.
Pull fuel pump fuse is a lot easier. No possible harm. But even that is usually overkill. Just start it.
Old Dec 23, 2025 | 07:14 AM
Chuck S's Avatar
Wrong question?
You can certainly crank the engine but you need those items in place to start it.
-- Chuck
Old Dec 23, 2025 | 08:38 AM
Originally Posted by Car Analogy
Yeah, I wouldn't pull plugs every year. More could go wrong vs tiny benefit. .
The spark plugs are only being pulled before the first start.
Old Dec 23, 2025 | 09:46 AM
I don't understand. If someone's process to take car out of winter storage is remove plugs, and if winter is a yearly occurrence, implies plugs removed yearly.
That doesn't seem like a good idea to me.
Old Dec 23, 2025 | 09:54 AM
Okay, I guess. I was removing plugs once a week while racing dirt bikes and autocrossing.
Old Dec 23, 2025 | 05:53 PM
darcyw's Avatar
I remove the fuel pump fuse and crank the vehicle over - WITHOUT the clutch pressed- until the oil light goes out. I also have installed a clutch interlock bypass so my car is no longer idiot proof.
darcy
Old Dec 24, 2025 | 03:59 AM
Nemerson's Avatar
I remove the fuel pump fuse. No need to complicate it too much.
