Thermostat problem?
The A/C, heat, etc... is not on. Yes, once the car warms up it comes on and does not stop. If I start the car and it is already warm from being recently driven and I am still at 3 bars on the temp guage, the fan will be on when started.
How is you coolant level in the reservoir and in the rad? When the engine is cold, remove the rad cap and have a look.
It's possible you have an air lock in the cooling system, a bad water pump, or a stuck thermostat. Have you done anything to your cooling system lately (boil over, flush, thermostat change)? Is your radiator blocked full of leaves?
The coolant level in the reservoir is at the proper level - thought also maybe it was low, but it is okay. Thinking it is just something I should take in to HOnda at this point. No blockage, I am meticulous about keeping the engine are clean and clear of leaves etc...
Thanks for your help!
Originally Posted by mds2000,Dec 8 2004, 07:08 PM
How do I bleed the coolant? If the thermostat is stuck, it needs to be replaced or can it be fixed?
https://www.s2ki.com/forums/index.php?showtopic=86811
Thermostats are relatively cheap compared to the labour involved in changing them. If it's the stat, buy a new one. You don't repair broken ones.
