S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Talk (https://www.s2ki.com/forums/s2000-talk-1/)
-   -   Throttle seems loose? (https://www.s2ki.com/forums/s2000-talk-1/throttle-seems-loose-336437/)
J Roman Nov 11, 2005 09:14 AM
When I step on the gas the pedal has to go down like an inch before any gas engages. What do I tighten to fix this? Is it the bolt on the throttle cable? And if so, to I turn it left or right to tighten it?
xviper Nov 11, 2005 09:51 AM
Go to the end of the throttle cable at the throttle body. There, you will see a couple of nuts that lock the end of the cable sheath to the bracket. You can adjust the free play there using these nuts. The correct tension is when you can move the middle of the exposed throttle cable up and down 1/4".
superjimbo Nov 11, 2005 11:50 AM
I was thinking about slighly tightening up my throttle cable for better engine response. However, due to my limited time under the hood, I don't know exactly where the throttle body/cable are located in the engine bay. Does anyone have a picture so I can reference it when I'm poking around under there? I'm sure I could figure it out myself, but a picture would be helpful :hello: Thanks!
robotkiller Nov 11, 2005 01:05 PM
This is so weird -- I've been screwing around with this today.
I adjusted the cable to tighten up the slack -- I have about 3mm of slack.
You have to loosen the forward nut (the one closest to the front of the car) and then screw in the second nut to tighten up the slack. Just make sure that at rest the throttle plate is not opened.
My problem is that now at full throttle I am not longer hitting the throttle pedal stop. I wonder if there is another adjustment loose somewhere.
http://i6.photobucket.com/albums/y25...1111051648.jpg
http://i6.photobucket.com/albums/y25...1111051649.jpg
J Roman Nov 11, 2005 01:43 PM
I took all the slack out of mine today and I like it much better. Now as soon as I push the pedal it gives gas. Before it had some give in it which I did not like.
superjimbo Nov 11, 2005 04:20 PM
Thanks, Robot! I'm gonna do it tonight!
silentdancer Nov 22, 2005 06:54 PM
you should have about 1/4 an inch i believe of slack
© 2026 MH Sub I, LLC dba Internet Brands
