Tranny Oil Analysis Results (Honda MTF vs Redline MT-90 vs Redline MTL )
Honda MTF
Titanium -0
Silver - 0
Copper - 0
Lead - 0
Tin - 0
Aluminum - 0
Nickel - 0
Iron - 0
Chromium - 0
Sodium - 0
Boron - 1
Silicon - 0
Water - 0
Soot - 0
Glycol - 0
Moly - 0
Magnesium - 11
Calcium - 2652
Barium - 0
Phosphorous - 1401
Zinc -1564
Visc@100C - 11.26
Tan mg/g - 0.30
Redline MT-90
Metal
Iron (Fe) 2
Copper (Cu) 0
Chromium (Cr) 0
Aluminum (Al) 3
Lead (Pb) 3
Tin (Sn) 6
Silicon (Si) 15
Sodium (Na) 18
Potassium (K) 21
Molybdenum (Mo) 1
Phosphorus (P) 2410
Zinc (Zn) 2750
Calcium (Ca) 2840
Magnesium (Mg) 11
Physical
Water (W) N
Fuel (F) /
Antifreeze (A) /
Viscocity At 40 C (V40) 0
Total Acid Number (Tan) 1
Total Base Number (Tbn) 3
Viscosity At 100 C (V100) 14.3
Particle
Redline MTL
Metal
Iron (Fe) 1
Copper (Cu) 0
Chromium (Cr) 0
Aluminum (Al) 3
Lead (Pb) 3
Tin (Sn) 5
Silicon (Si) 25
Sodium (Na) 21
Potassium (K) 11
Molybdenum (Mo) 1
Phosphorus (P) 2520
Zinc (Zn) 2820
Calcium (Ca) 2860
Magnesium (Mg) 11
Physical
Water (W) N
Fuel (F) /
Antifreeze (A) /
Viscocity At 40 C (V40) NR
Total Base Number (Tbn) 4
Viscosity At 100 C (V100) 11.2
Iso Code Rating (Iso) 19/12
It looks like the Honda MTF has the same visc @ 100C as the Redline MTL. I think a slight mix of Redline MTL (1.2 litre) and MT (0.5 litres) would good to give it a bit more visc for summer.
Titanium -0
Silver - 0
Copper - 0
Lead - 0
Tin - 0
Aluminum - 0
Nickel - 0
Iron - 0
Chromium - 0
Sodium - 0
Boron - 1
Silicon - 0
Water - 0
Soot - 0
Glycol - 0
Moly - 0
Magnesium - 11
Calcium - 2652
Barium - 0
Phosphorous - 1401
Zinc -1564
Visc@100C - 11.26
Tan mg/g - 0.30
Redline MT-90
Metal
Iron (Fe) 2
Copper (Cu) 0
Chromium (Cr) 0
Aluminum (Al) 3
Lead (Pb) 3
Tin (Sn) 6
Silicon (Si) 15
Sodium (Na) 18
Potassium (K) 21
Molybdenum (Mo) 1
Phosphorus (P) 2410
Zinc (Zn) 2750
Calcium (Ca) 2840
Magnesium (Mg) 11
Physical
Water (W) N
Fuel (F) /
Antifreeze (A) /
Particle
Redline MTL
Metal
Iron (Fe) 1
Copper (Cu) 0
Chromium (Cr) 0
Aluminum (Al) 3
Lead (Pb) 3
Tin (Sn) 5
Silicon (Si) 25
Sodium (Na) 21
Potassium (K) 11
Molybdenum (Mo) 1
Phosphorus (P) 2520
Zinc (Zn) 2820
Calcium (Ca) 2860
Magnesium (Mg) 11
Physical
Water (W) N
Fuel (F) /
Antifreeze (A) /
Can we safely assume that the oil pump in the S2000 transmission can handle 90 wt gear oil? For other transmissions that isn't a consideration, but it is for this car.
Thanks,
svatne
Thanks,
svatne
MT-90 is not a 90 wt gear oil. It is just slightly heavier than the OEM fluid. The owner's manual specifies an equivalent engine oil viscosity of 5W-30 to 10W-30 (or 10W-40?). Redline MTL is closer to 5W-30, and MT-90 is closer to 10W-30.
Actually, MT-90 is a bit beyond 10W30. SAE 10W30 has a visc of around 9.6 to 12.5 @ 100C. The MT-90 is 14.3 @ 100C.
Gernby, for TX, summer MT-90 is perfect. How are your grinds?
still confused on what all that meant...I am about to change my tranny oil, but still don't know which brand to go with. ...Honda MTF, Redline MTF, Redline MT-90, Neo MTF....
