V-AFC or II problem..
Old Nov 17, 2003 | 06:33 PM
owenxguo's Avatar
Default V-AFC or II problem..
Can anyone give me the V-AFC wiring manual for MY00 S2000?
I can not find on Apexi website.
thx a lot!
Old Nov 17, 2003 | 06:41 PM
3ngin33r1's Avatar
V-AFC ver 1 ONLY
Red; Power; ECU B1; Yellow w/ Black stripe (splice in)
Orange; Power; ECU B1; Yellow w/ Black stripe (splice in)
Black; Ground; ECU B20; Brown w/ Yellow stripe (splice in)
Brown; Ground; ECU B20; Brown w/ Yellow stripe (splice in between V-AFC Black wire and ECU)
Green; RPM Signal; ECU A19; Blue (splice in)
Grey; TPS; ECU C27; Red w/ Black stripe (splice in)
Blue; VTM Signal; ECU C10; Blue w/ Black stripe (cut ECU wire and connect to ECU side)
Purple; VTi; ECU B12; Green w/ Yellow stripe (cut ECU wire and connect to ECU side)
Pink; VTo; VTEC Solenoid; Green w/ Yellow stripe (cut ECU wire and connect to VTEC solenoid side)
Yellow; MAP output; ECU C17; Green w/ Red stripe (cut ECU wire and connect to ECU side)
White; MAP input; MAP Sensor; Green w/ Red stripe (cut ECU wire and connect to MAP side)
Old Nov 17, 2003 | 09:56 PM
owenxguo's Avatar
wow thank you very very much
Old Nov 17, 2003 | 10:14 PM
3ngin33r1's Avatar
Sure thing.
ihiryu
Apr 24, 2014 08:02 AM
BUDRISS
Mar 23, 2006 09:43 AM
Moemers
Jul 12, 2005 09:27 AM
RT
Jan 28, 2003 08:18 PM
