S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Talk (https://www.s2ki.com/forums/s2000-talk-1/)
-   -   VTEC not VTECing (https://www.s2ki.com/forums/s2000-talk-1/vtec-not-vtecing-5917/)
Spectre Jan 25, 2001 12:42 PM
This has probably been posted b4. I've had 2 consecutive oil changes with Castol Syntec. I've got 8K on the odo. My oil level is perfect. Ok, here is what happens....nothing.
I don't feel any surge or don't hear the change in engine tone like I use to. The car revs smoothly to 9k with no change in feel at the VTEC rpm range. Any ideas or suggestions???????????????????
Thanks
Tox Jan 25, 2001 12:50 PM
This is in first gear?
S2WOOOW Jan 25, 2001 12:50 PM
It's probably not the oil. I've been using Syntec with no problems.
Did it start when you switched to Syntec or just started recently.
ricosuave Jan 25, 2001 01:01 PM
i've got the same situation. i guess the synthethics work too well and smoothing the engine. i've been using mobile 1 for my oil and the surge seems to have diminished. i wonder if using regular oil would cause the surge to return?
Luder94 Jan 25, 2001 01:32 PM
Pull the meter fuse! This will disallow VTEC to engage...now drive the car. Does it feel any different than before? If you don't get that as quick acceleration from a moving start, then your VTEC was VTECing with the fuse in.
That's the method I've used to diagnose Prelude VTECs. I think it may work with the S2 also.
Hootsama Jan 25, 2001 01:35 PM
MAP sensor is shot, maybe?
Spectre Jan 25, 2001 03:43 PM
Thanks for the suggestions. I am going to give them a try.
Need my VTEC fix!
Spectre Jan 25, 2001 03:59 PM
[QUOTE]Originally posted by Luder94
[B]Pull the meter fuse!
© 2026 MH Sub I, LLC dba Internet Brands
