WARNING: Your S2000 could be a theft target!!!
Well, not really, but it could resort to that. I was browsing www.newcelica.org, because I like the car. I looked through their FAQ section, and what did I find? The Honda part number for the S2000 antenna! Reading further, it appears that you can screw in the S2000 antenna into the Celica, for a cleaner look. Check this thread for pictures: http://www.newcelica.org/ubb/Forum4/HTML/002631.html
So, if you see a Celica owner looking over your car whistfully, you know why. Just thought you might find this interesting.
If you're worried just put a little lock tite on the threads. But use the kind that is made to be removed, the other type could be impossible to remove.
For a more extreme solution, roll the antenna in a clear glue/crushed glass mix. It would be a bit sparkly and be a real pain to remove
