Rather than add FI to my cars and stress the engine/transmission etc. I prefer to reduce the car's weight to improve the performance. In the S, besides removing the spare tire/jack/tools etc. what else can be removed to make it lighter without removing the A/C (TX heat) and the radio?
Anyone know the weight of the spare tire and jack etc.? What is the weight of the motor for the power top? TIA
i dont think weight reduction is gonna do much compared to FI
super street did a test on how much u gain from weight reduction
the results?
its not as much as u think it is
1 lb = .0021 in 1/4 mile (nice baseline computation which is about right with cars of this power to weight ratio).
IOW, remove 100-lbs and you should see a drop of .2 seconds in your 1320.
That's two car lengths (more or less) at these trap speeds.
The spare tire, jack and tool kit is around 30-lbs.
Tires/wheels is the first place I'd start if you're serious about losing weight.
The battery weight can be shaved (see s2ki.com marketplace), you can replace the seats with 12-lb racing seats, etc.
A titanium dual can drop another 35-40-lbs off the OEM system (52-lbs) or for even bigger weight gains, go with a single Ti exhaust.
I replaced my mirrors (fairly heavy...about 5-lbs each) and steering wheel (that air bag assembly is heavy) with a carbon fiber D-wheel.
Changing the OEM air box with an AEM, INJEN, etc. can save a few more lbs as well.
Then again, you're talking $2-3K if you add all this up (wheels/tires, cf mirrors, cf steering wheel, intake, exhaust, etc).
Yup, 16x7 ET45 w/ 205/50/16 and 225/45/16 Toyo Proxes T1-S (total tire/wheel weight about 33-lbs per corner). Tires are .8 inches shorter than OEM, the car has been lowered with a Tanabe NF kit (1.25-inches). Here's an older pic
-1 PRM Intake
-25 Spare Tire
-2 Trunk Trim
-7 Tools/Jack
-1 Mats/Visors
-30 (1/2 tank of gas)
-12 Optima Battery(see S2ki Store--easiest and cheapest way to drop a lot of weight
-15 Recaro SPG/Taitec rails
-5 Center Console
-10 Stock Rollhoops/Plastic (only take off of course if you go with aftermarket rollbar)
-2 Washer Fluid
This put me at 2734 with a ~60lb Bitterbar and Digrappa XBrace
Then I went with:
-1 Alum Pulleys
-30 Wilwood Brakes
-5? Interior Carpet
-15 Sparco + Taitec
A lightweight exhaust can drop another 20-30lbs easy. But with no carpet/sound deadening material it's wayyyy too loud.
