Werid ass clicking noise
Old 07-27-2017, 07:36 AM
Xeon's Avatar
Default Werid ass clicking noise
Hi guys let me get started off by saying it's not the axle nut
So so between approx 5-15 mph I hear a click click noise coming from the rear drivers side wheel after 15mph the sound goes away I checked for wheel play and I found non
Old 07-27-2017, 08:05 AM
s2000Junky's Avatar
I has a similar sound I was chasing. Turned out to be the diff. Sounded like it was coming from pass side, but was actually center in diff. Also had a pretty good vibration at freeway speed.
Old 07-27-2017, 09:55 AM
Xeon's Avatar
I dont have have any vibrations and I have the axle spacers
Old 07-27-2017, 10:33 AM
Xeon's Avatar
I feel that it's so weird being that it only happens at low speeds
Old 07-27-2017, 11:24 AM
s2000Junky's Avatar
That you can hear.
Old 07-27-2017, 11:59 AM
Xeon's Avatar
No I am pretty sure it's only low speed I have turned my car off going 25 and I hear nothing as soon as I go under 15 boom it stars to click
Old 07-27-2017, 12:04 PM
Car Analogy's Avatar
Received 1,315 Likes on 993 Posts
And you know its not the axle nut because?
What if axle nut is torqued properly now, but for a long time car was driven with axle nut at original factory setting, which has proven to be insufficient, and the damage was done. Now that its torqued properly, it doesn't magically heal anything. It also doesn't magically eliminate any future wear. It still wears even when properly torqued, just not nearly as fast as if its not.
Maybe it still wasn't making noise when axle nut was torqued to updated spec. But now, some miles, and some wear later, it is.
Old 07-27-2017, 12:29 PM
Xeon's Avatar
so so what your saying is maybe I need a new wheel bearing and hub
Old 07-27-2017, 01:02 PM
Elistan's Avatar
Sounds like a failing wheel bearing. Happened on both my S and my wife's S.
Old 07-28-2017, 12:27 PM
hoobastnk90's Avatar
wheel bearing on mine failed, I don't remember a clicking noise but when I turned left or right it would load up the wheel with the bearing problem and make a lot more noise. Ignored it for awhile eventually got worse to the point where it was making noise always.
KyungMin
02-13-2014 04:13 PM
s2kbenztech
Tampa
09-22-2009 01:54 PM
Euroflavor
03-30-2009 10:39 AM
NFRAP1
08-20-2008 04:18 PM
-DOZER-
11-06-2007 04:33 PM
Quick Reply: Werid ass clicking noise
