What parts typically replaced when hydrolocked
What parts are typically needed to be replaced? How much are these parts typically including labor? I think I may have water damage...
Well my car was on my driveway through a thunderstorm. Subsequently, I started the car to put it back into my garage (I was lazy), and during this my car just stopped. Now it doesnt start and jump start wont work and my battery was recently replaced.
How high did the water get to? I don't think you'd have a hydrolock situation unless it was sitting in a big puddle or you drove through one. It's been raining soooo damn much here the last few days, but I don't think you'd have a hydrolock situation just with the car just sitting through a thunderstorm unless a deep puddle developed or you left the hood open. You don't have one of those CF hoods with vents, do you?
Warren
Warren
Does it crank? If it cranks it's not hydrolocked. Do you have a cold air intake? Unless you suck water into the engine through the intake, you're not going to hydrolock.
Typically hydrolocking either does nothing and you can pull the plugs and crank the motor to push the water out, it bends the rods which means the engine needs to come apart or it cracks the block which means you need a new shortblock. Normally it doesn't affect the valves.
Former Sponsor
^ This is not true. If you have an AEM V2, or even the first gen AEM and INJEN there is a possibility to hydrolocked while parked on a incline like a drive way. The way the filter is positioned (especially the AEM V2, with its slight tilted filter), and how a drain hole on the S2K dumps right above where the AEM/INJEN CAI filters sit can cause the intake to gather enough water at the bottom of the intake. Enough water that when you start the car it will get sucked into the car.
What could it be?
I dont have a CF hood, but I do have a CAI intake. Did not drive nor sit in a puddle. It cranks, it just doesnt turn. My home just had a leak also and the roof needs to be replaced also. I guess when it rains it pours
It's happened to me, and it wasn't even raining very hard. I knew this would be a problem with my AEM V2 so I took a blowdryer and tried to dry out the intake as much as I could before I started the car. When I started it, it ran fine, but then a few minutes later the car died. But, I was able to restart it after many cranks and it's been fine ever since. This was more than a year ago.
So, yes it is possible to hydrolock your motor with an AEM V2 even if the car is just sitting on the driveway.
Former Sponsor
Originally Posted by YeLLoWs2knVA,Jun 26 2006, 09:36 PM
What could it be?
