S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Talk (https://www.s2ki.com/forums/s2000-talk-1/)
-   -   Whine when going backwards (reverse) (https://www.s2ki.com/forums/s2000-talk-1/whine-when-going-backwards-reverse-470282/)
ej3ffrey Mar 12, 2007 11:13 AM
The past couple days I've been hearing this whining sound from the back of the car. It only happens when I'm going backwards... it happens in reverse and after i pop it back into neutral. It's a constant sound while the car is moving and stops when the car is stopped or moving forward. It doesn't happen in any other gears. Any input on what's going on?
JLUDE Mar 12, 2007 11:18 AM
It's your rear differential. I heard it too, only in Reverse but it's not that noticable. Have you flushed the diff fluid recently? I do mine every 10K miles!
All manual transmission cars have a whine/hum sound when in reverse, it has to do with the fact that Reverse gear is a straight gear, not helical like the forward gears. I think the frequency of this "whine" sound transfers through the driveshaft to the differential and rear axel which makes it more apparent. It's not as noticable on my FWD Prelude.
Brennon Mar 12, 2007 11:19 AM
They all do that sir.
ej3ffrey Mar 12, 2007 11:40 AM
well, this is a sound that i've never heard before... so it's probably different than the usually whine. i'm gonna flush the differential fluid and see if that's the problem.
vtec9 Mar 12, 2007 11:47 AM
they all whine when in gear.. don't know if my S whines while out of gear .. I've never coasted in reverse :)
ej3ffrey Mar 12, 2007 11:50 AM
i wasn't coasting at like 20mph in reverse lol
when i'm backing out of my driveway, i put it in reverse and get to about 2/3mph then pop it in neutral and coast off the driveway until im ready to go forward, into 1st. during this whole time of going backwards, i can hear the whine.
gomarlins3 Mar 12, 2007 07:47 PM
I don't notice it when I am in neutral.
greenjack Mar 12, 2007 08:32 PM
That's because the reverse gear isn't engaged in neutral.
common reactor Mar 12, 2007 09:25 PM
I thought this thread was a joke by 2HEATY or something
JLEEzAP2 Mar 13, 2007 12:06 AM
Sometimes when just being in gear with the clutch all the way in and rolling, you'll hear a slight whine from the gears.
© 2026 MH Sub I, LLC dba Internet Brands
