Whoa!
Wow! If you guys have never tightened your throttle cable, then you should go do it now! The difference is amazing. I wouldn't have had as much trouble learning to drive the car if I had done this when I first got it. Go do it!!! :thumbup: :D
Thanks for sharing. How did you do this exactly? Was it easy?
i would post, but mine is a model 06... its DBW. i did this for my old celica, there should be a throttle cable right in front of you when you open the hood, can't miss it. use an open head wrench and there should be some kind of hex nut there that controls the tension... or at least thats what i found in my toyota. it works wonders, but dont pull it too tight or your idle will also go up and you'll be burning lotsa gas
i did this within the first 2 days of owning my car. you should tighten it so it has about a half inch of movement of either side when you push on it. mine had like 2 inches of slack it was nutz.
this is one of the most noticeable improvements i've done to the car. the feel is so much better on the pedal that your a retard if you don't do this maintenance. seriously its so simple and it makes the whole driving experience better...pulling out is easier. you have more throttle control that feels like its 100x better than before. there are two nutz you have to adjust on either end of the end of the cable's shell...you tighten one and then tighten the other. you might need two tools to get it tight...wrench + socket+ratchet... |
I agree, great tip... thanks for sharing ... I just did it and the trottle feels soooo much better
:thumbup: |
just remember to keep about 1/4 inch of play in the cable when pushing up
I did it a few years ago when the thread was first mentioned, but I haven't checked it lately. Maybe I should.
maybe I will.. maybe I won't
http://www.lifeprint.com/asl101/sign...m/maybe.34.jpg http://www.gonomad.com/globalroam/up...her-714837.jpg |
| All times are GMT -8. The time now is 02:45 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
