Will these wheels fit ?
Old Dec 19, 2000 | 05:29 AM
mt2000's Avatar
These wheels manufactured by Volkracing for Toyota Racing Development (TRD)come inthe following sizes:
18x7.5 offset +50 for the fronts
18x9.5 offset +55 for the rears
Anyone know if these wheels will fit , especially the rear ones ?
Old Dec 19, 2000 | 05:51 AM
Sam Yau's Avatar
Yes these wheels with the offset should fit. I have 18x10 with 60 offset(285-35-18 tires)and there is no rubbing at all.
Old Dec 19, 2000 | 07:02 AM
RT's Avatar
RT
Are you sure about that +60?
Old Dec 19, 2000 | 10:26 AM
Ben's Avatar
Ben
18x10 with a 60? No wonder he's selling the wheels so soon...
The volks you mention will fit, but not nicely. Sounds very similar in the rear to the BBS LM wheels, which were also a 9.5 and 55 offset if I remember correctly. Well, I've seen those LM wheels on an S2000 in person and they were a terrible fit. Stuck out a ton past the rear fender. Not recommended...
Does the TRD/Volk wheels have the same bolt pattern and hub bore front and rear?
Old Dec 19, 2000 | 10:46 AM
Sam Yau's Avatar
Kinesis told me that the specs. were 18x10 with a 59/60 offset in the rear. These wheels with 285-35-18 in the rear does not rub at all even with a 2 inch drop from the Feels Suspensioin.
Ben- For your record, I am not selling these wheels because they dont fit. See the attached pictures for yourself. These wheels/tires fits just as good as your HREs if not better buddy. Dont make false assumptions until you have personally see the car.
http://albums.photopoint.com/j/ViewPhoto?u...7135&p=35265148
http://albums.photopoint.com/j/ViewPhoto?u...7135&p=35265139
Old Dec 19, 2000 | 11:32 AM
mt2000's Avatar
Ben, the bolt pattern is the same ~ 5x114.3. What is the hub bore - I did not check on that.
Thanks for the info about the BBS LM - Now I also recall seeing pictures of this wheel. It gives a good idea of how that wheel may look on the s2k.
Old Dec 19, 2000 | 11:36 AM
mt2000's Avatar
BTW Ben, what offsets are the HREs.
Sam, the fit of the kinesis seem to be very good given the sizes of your rear tires...cool.
Old Dec 19, 2000 | 11:48 AM
RT's Avatar
RT
Sam, if you got the wheels off the car give it a quick measure. I'm guessing more like 69/70 instead of 59/60. I'm running 9.5's at a +64 which would converts to a +70 on the 10" wheel (equal front spacing) and it's got zero room on the frt side, ZERO.
Old Dec 19, 2000 | 12:12 PM
Sam Yau's Avatar
I will check on the offset myself when I get a chance. Perhaps Kinesis did make a mistake with the info. that was provided to me.
Since you are in Australia. Have you heard of a co. call Simmons? They made custom applications as well and their prices are cheaper than HREs, Kinesis, Fikse, etc. You might want to look them up.
Old Dec 19, 2000 | 03:07 PM
G1S2k's Avatar
What are those TRD/volk wheels for? The new MR2 Spyders? Or the Supra? Those would look good on the MR2.
Desmond
Silverstone/ Red S2k #2219
