HID lighting info website takes me to a different website.
any info on soft top de-burring?
Here's a list of my How-To's
Build an S2000 Race Car S2000 Valve Adjustment DIY Alignment Replace S2000 Wheel Bearing Compression & Leak Down Tests Install SPC Adjustable Camber Ball Joints Install Brake Ducts Install APR GTC-200 Wing Swap the Differential Install Racing Harnesses by Matt Install a Fire Suppression System by Matt Remove Air Conditioning Racing Exhaust Oil Catch Can Install Roll Center Adjusters Install Front Bump Steer Kit Remove Catalytic Converter Pedal Mod for Heel&Toe Corner Balance Replace Suspension Bushings Replace the Radiator Install an Oil Cooler S2000 Aerodynamics |
Serpentine Belt:
http://dave.harris.net/s2000-replaci...uxiliary-belt/ Rear Drop Links: http://dave.harris.net/s2000-changing-rear-drop-links/ Rear Brake Pads: http://dave.harris.net/replacing-s2000-rear-brake-pads/ |
Any dyi threads on replacing transmission mounts?
+1 on roku's inquiry.
Replacing the transmission mount is actually really easy. You remove a total of 7 bolts the 3 on the end that bolts it to the chassis and then 4 bolts that bolt the mount to the tranny and it comes right out. I replaced mine the other day with the innovative mounts
found this and thought it should be added to the list (bumper tab relocating)
https://www.s2ki.com/s2000/topic/837...tab-relocated/ |
does anyone have a breakdown of how to replace your carpet? Im trying to replace mine but run into a couple road blocks. Thanks
