[P1399] Engine misfire, what else to do?
Hi all,
Been having engine problems lately and am looking for some pointers on what to do. Running out of clues myself. I own a December 1999 S2000 with ~196K km (little under 120K miles) on the clock. In January this year I had some maintenance done to the engine, after which issues slowly started building up (or so it seems). What was done at the time was the following;
Got a ODBII reader and red the DTC's. Turned out to be P1399 and P0301. Obviously I contacted the person that did the maintenance, who has been every so helpful! Got loads of great suggestions and helped assist with a couple of things. Additionally used some of the misfire threads here on the forum. What was done to fix/diagnose the issue?
My maintenance guy suggested that it could be;
In case of any trolls, yes I didn't change the blinker fluid. ;) |
Small update. Started the car again last night (engine was cold).
Fired up instantly, no problems turning over. Sounded ok, not rattle. Waited for the car to go off the choke, after which I slowly increased the throttle a couple of time. CEL lit up, so I read the values
Originally Posted by vwaart
(Post 24449854)
If it is drinking a lot of oil (smoking a lot), this can cause misfires as well....did any of your plugs have oil on them? |
Originally Posted by HawkeyeGeoff
(Post 24450156)
Sparkies are new; try finding a local with known good parts and swap the coil packs onto it from theres and see if it changes.
Did you guys check your coil packs closely too see if they were wet with oil? If your spark plug hole gaskets have never been changed inside your valve cover then they will definitely flood oil into the coil packs chambers causing misfires and killing the coils. Change them out with OEM replacement ones and swop the coils with the new ones to see if that cures the problem - I'm sure it will unless that oil pump really has gone bad...
Originally Posted by RolanTHUNDER
(Post 24450360)
(Post 24450362)
Good suggestion! The seals have been replaced with the same maintenance in Jan, just checked the invoice. I will check when replacing them, if the coils are wet with oil and report back.
Every single time this comes up people say plugs and coil packs. Inevitably the OP responds that the plugs are new or new-ish. So they swap coil packs around and/or buy new ones - and that never works either. I think it's injectors. Why doesn't anyone ever try new or rebuilt and balanced injectors?
Originally Posted by 92gli
(Post 24450402)
The oil light flickering at idle and the hard start after warm-up is the 1st problem I'd chase. Check your oil pressure with a mechanical gauge and crankshaft end-play (thrust washers?) Before doing anything else.
