06+ DBW throttle wire adjustment
This may alleviate all the comments about lag in the drive by wire system introduced in the MY06's. I was wondering what was in that black box on the driver side so I popped it open and tadaa:
http://www.we-todd-did-racing.com/we...ZkMzF5NTQx.jpg There was actually quite a bit of slack in the wire, just as in the throttle cable of the good ole pre-MY06's and B-series engines. Simple procedure: 1. Undo 10mm bolts A and B to open the black box. 2. Feel slack by pushing down with finger at E. 3. Hold the whole contraption with one hand and undo 12mm bolt C. 4. Turn bolt D so that it tightens the wire. 5. Tighten bolt C again. 6. Test slack at point E again but make sure you tighten so that the swivel is closed at rest. You want to be just a bit on the loose side. 7. Put the black box on again with the 10mm bolts and you're done. You should experience a slight improvement as the throttle will feel tigher. :burnrubr: :woot: |
hmm im new to s2k but coming from VW mk4 gti application i assumed DBW meant no throttle cable at all? mine is all electronically controlled. if this is the case with the s2k why ist here any cable to adjust?
I can't notice a difference at all in lag and I didn't even know about this. I thought the same as bronfufu that there were no cables whatsoever.
I might try this just to see if there really is a difference. Like most "free" mods you'd be hard pressed to acually tell if you did anything at all. |
Sorry about the miss information , Posted by one of my workers as I didn't log out .
This post has been edited by Scott |
Here is a picture of the throttle body with its "DBW" solenoid mounted right on the side:
http://www.slhondaparts.com/browse.asp?Mod...&ViewParts=true Here is a pic of the "accelerator pedal sensor" (which looks more like what's pictured above): http://www.slhondaparts.com/browse.asp?Mod...&ViewParts=true |
Originally Posted by Twiztid,Sep 22 2006, 11:45 AM
That is the cruise control not the DBW system .
Adjusting it will have no effect on the response . THAT IS THE THROTTLE CABLE ADJUST FOR THE DBW ON A 06 Sorry Boofster and xviper , I will make sure I log out this time :banghead: |
[QUOTE=xviper,Sep 22 2006, 08:27 AM] Drive by "Wire" only means that there is no direct linkage between the gas pedal and the throttle plate.
1 Attachment(s)
