1999 s2000. engine cuts out at 7000 RPM
My local honda dealer has them all the time. Did you check honda?
S2000'S are very rare here .... so even the dealer doesn't stock parts .
Solved finally!!!
So finally got all my parts in, And got my self back home so I can work on my S. Installed a new Vtech pressure switch, then stripped one of the bolts of the spark plug cover.... Big mess.....
On my way to an expert to remove the stripped bolt I decided to floor it and it purred all the way to 9000RPM....
It was a bad Vtech pressure switch causing this...
moxie50 (06-18-2020)
S2000 p1399 & p0301
My Engine Management Light EML came on.
i changed the spark plugs and coils and then it came on again after a week so I replaced the rocker cover gasket and seals and engine oil flush. Which helped for a few days came back on....
i got new seals for the vtec solenoid helped for a week came on again.
i change the coils and spark plugs back to originals Denso and NGK and did a timing adjustment. The 02 sensor was also loose on the cat which was tightened up.
now it’s worse than before cuts out at 7000rpm
things I Havnt done
Coolant flush
map and knock sensor
changing the fuel injectors.
can anyone help ? I’m annoyed as hell
things I Havnt done
Coolant flush
things I Havnt done
Coolant flush
things I Havnt done
Coolant flush
