2.3 Stroker Kit
2.3 Stroker Kit
I wanted to see if anybody out there has installed the 2.3 Stroker Kit on their car. I am in the process of purchasing one thru Bulletproof Auto. They have informed me that I am the first one to order one, and he gave me the impression that they might be the only provider of this kit. I am trying to get some technical info on the compression and other stuff. If you have any info let me know.
Ron Smith
Ron Smith
I think it will be able to, because it will have a little lower compression, and I am also thinking about having the heads ceramic coated. I am going to install this kit first, and then find out what safe level of boost I can run, then put a supercharger in with a high boost pully, and put a blow off valve to regulate the boost once it is at maximum level.
Ron Smith
Ron Smith
When the heads are ceramic coated, they can better withstand both boost, and nitrous. I forgot to mention that I would be eventually putting a 75 shot direct port kit on the car.
Ron Smith
Ron Smith
