^Correct. Nothing needs to be done at all. Just leave the steel snake shaped cover in place. |
Posting identical questions in multiple locations just fragments the responses.:banghead:
You milled the block. Not sure what effect this will have and it was noted but not answered in either of these fragmented threads. -- Chuck |
Originally Posted by flanders
(Post 24457716)
Those holes leads back to to intake side of the head and on a non dbw car it connects to the intake manifold.
Your dbw intake manifold doesn't have this opening and will just block it off. |
Originally Posted by Billman250
(Post 24457719)
Originally Posted by Silver_Bullet_S
(Post 24459097)
Are the intake/exhaust manifold gaskets & head gasket all the same for all the S2000 years?
Slightly different question from my side, have searched it, but just to make sure.
I have an early 2002 S2000. lower block is shot and I can get a new (F20c) 2009 lower block. Is it plug and play, on my 2002 head, intake and harness / sensors? I believe it is, since there are almost no difference in the lower blocks through the years. Thank you very much. |
Originally Posted by Delta_lima
(Post 24553330)
Its both a F20c (2,0) not sure if the new engine will come with a crank sensor. But the old one (2002) will be mounted, thank you! is the harness plug different? Or a different sensor? |
Both plug and sensor is different, you will also need to replace the trigger wheel.
Ai, serious? That would mean to remove a factory sealed carter and chain cover :/ |
