2004 S2K overheating, fan not coming on
Old 04-21-2017, 03:41 AM
torrezdavids's Avatar
Default 2004 S2K overheating, fan not coming on
my honda s2000 fan not coming on, and i notice alot of brown sludge coming from the radiator. Please help
Old 04-21-2017, 07:06 AM
Fat
Fat's Avatar
I had to replace the fan motor for the radiator fan because it went out, causing it to overheat. Does the a/c condenser fan (driver side) turn on? If both are not working it may be a fuse.
I'd check the fuses first either way as its free and easy to do. Try hooking the motor to a direct 12v supply and see if it runs. If it doesn't it's most likely dead. It may also be your thermostat, I think you can check that by feeling the lower coolant hoses and if its cold(er) to the touch than the top, that's the issue.
I'm not an expert by any means, but this is just what I've gathered in research when I was diagnosing my issue.
As for the brown sludge I have no idea.
Old 04-21-2017, 12:38 PM
Mexs2k's Avatar
Brown sludge sounds like a blown head gasket.
Old 04-21-2017, 12:49 PM
Fokker's Avatar
The easiest way to check if the fans are working is to turn on the AC (the car doesn't have to be running, just with the key in the on position). While the AC is on both fans should spin. If they are working, then you most likely need to change the fan switch (temperature sensor in the lower corner of the radiator). If the fans do not spin when the AC is running, then apply direct 12v to verify that the motors are functioning. If functioning, then you'll need to chase down the electrical system to determine the fault; if not then replace the fans. If the thermostat had failed, you would notice that much sooner under any normal driving conditions as there will be no coolant circulating through the radiator and the car will overheat in a relatively short space.
Old 04-25-2017, 02:53 PM
jyeung528's Avatar
your radiator taking a shet, get some toilet paper.
Mr Snow
01-31-2017 06:08 AM
aphex4000
05-28-2015 03:44 PM
BBW3
07-01-2014 07:03 PM
9kred
07-03-2012 09:44 AM
midwesta
09-28-2009 04:11 PM
Quick Reply: 2004 S2K overheating, fan not coming on
