4th to 5th "crunchy"
Like said, just a little "crunch" when I first go into 5th, or if i. Haven't done it in a while.... but it goes I'm very smooth always with no clutch... anyone explain that?
Change your clutch fluid more often.
okay, lemme make this a little more clear....
yeah, i could drive the car all day without the clutch no problem... i dont.
when i use the clutch to shift from 4th to 5th, it grinds...
when i do not use the clutch to shift from 4th to 5th, it is very smooth...
**brand new clutch fluid its been doing this since i bought it
This thread (yours) seemed to deny this assertion You're saying that the only time it grinds is when you use the clutch. Sounds like the clutch ain't disengaging or the syncros are buggered from not using the clutch. Maybe before your ownership.
-- Chuck
-- Chuck
You willing to drop the gear box and look inside? I'd at least flush it and see what comes out. Aftermarket clutch complicates things. Older cars had different synchros. Hard to tell without looking. Re greased the shifter and put the lever back oriented the right way?
-- Chuck
-- Chuck
