ABS kicking on... Lightly braking 5-20mph
Old 05-12-2011, 05:06 PM
///MIKE's Avatar
Default ABS kicking on... Lightly braking 5-20mph
Ok, it feels like my passenger side abs is kicking on while the car comes to a stop. I bled the brakes today... Didn't fix it. I also cleaned all 4 sensors and that didn't fix it either. The abs light is not on, nor does it come on. I checked all mounting bolts for the calipers and they're torqued properly.
I can't figure this out. Found another thread on s2ki that seemed like a similar problem... They sanded down the area around the abs sensor to get it closer to the rotating portion of the hub... Mines pretty close. I know... "pretty close" isn't the best description... However, it appears to be the same distance as all the other sensors.
Could I maybe just have a bad passenger / front abs sensor?
Another idea I just had... Can I unplug each sensor one by one to see which wheel is actually having the "issue"? Or, will the abs system just freak out?
This is really ticking me off.
UPDATE** ABS on front right wheel is on all the time. I can get out of the car, and go feel it pumping on the front right wheel. WTF?
Old 05-12-2011, 05:18 PM
joes sled 2000's Avatar
One of the sensors is on its way out . It just hasnt tripped an abs light yet .
Old 05-12-2011, 05:20 PM
///MIKE's Avatar
Is it necessarily the passenger side?
Old 05-12-2011, 06:33 PM
Slows2k's Avatar
One of the wheel speed sensors is sending an erratic signal. You'll need an oscilloscope or a very $$ scan tool to determine which one.
What suspension work was recently done?
Old 05-12-2011, 08:09 PM
///MIKE's Avatar
Nothing... Suspension has been the same for awhile now. Actually, just remembered I had a new alignment done. Added more front camber (2.9). Could that have something to do with it?
Old 05-12-2011, 08:27 PM
Slows2k's Avatar
If this started after suspension work or a tire was replaced it's probably related. If the sensor isn't mounted flush to the knuckles or corrosion on any of the tone rings can cause an erratic sensor signal. A tire that has unequal height can cause the same.
Old 05-13-2011, 07:24 AM
///MIKE's Avatar
I really appreciate your help. Here's the thing. All 4 wheels / tires are IDENTICAL. Same size, offset, and tires are brand spankin' new.
I'll double check the sensors to make sure they're seating properly.... This is so annoying.
Btw, on a cold start this morning, sloping kind-of down hill... the abs was going nuts while I was completely stopped. I don't understand that at all...
Old 05-13-2011, 02:06 PM
Slows2k's Avatar
Where tires just replaced? They may not really be identical sizes. does the car pull while driving at highway speeds?
Old 05-14-2011, 07:25 AM
///MIKE's Avatar
Car does not pull. Tires are all new and are all the same size / same manufacturer. All the wheels are the same size / diameter.
Pulled sensor last night, sanded down cradle surface, and put it back in... seems to help a little bit. The abs was not as pronounced this morning during my commute. I'm bought a new sensor for the front passenger side... I'm going to try that when it comes in.
Old 05-14-2011, 07:55 PM
Slows2k's Avatar
You have someone local you can swap wheels speed sensors with? I've got Honda HDS that can graph wheel speeds but it's a little pricey for DIY use.
Quick Reply: ABS kicking on... Lightly braking 5-20mph
