AIR PUMP KIT ... where to place the resistance?
Hello everyone . first thank you for reading this post . i have a problem. buy a s2000 and I came without air pump . It is a UK version . The problem is that I turn on the light of the CEL . I've seen several posts about the resistance. and buy . but do not put it exactly that connector . I removed the front bumper and I found this. upload photos. I'm desperate to remove the CEL light with the P1412 fault and resistance is achieved but how?
Donde esta la bomba de aire?
I know, I just want to know what happened to it
Well I can't say I've ever bypassed the air pump, I'm guessing that that resistor is used to simulate the air-pump, so you would have to rig the connector from the air pump and wire it to the resistor.
and the image which is the connector is you speak of ?
I don't know, there's supposed to be 3 connectors, two for the air pump relay, and one for the air pump itself.
The relay has a small and a large one, all three are two pin connectors, and the main connector is large like one of the relay ones.
if you still have not relay the famous air pump . the previous owner would take it all . I have to do to get remove light cell is to buy a relay. and then connect the resistor to the relay ? is that correct?
