Aircon Compressor Clutch
Hi all - this is my first post in this forum.
I own an AP1 - I have noticed that the AC clutch doesn't spin at all even with AC turned on. I check the wire by multi-meter and can't see any voltage going to the compressor. For testing - I connected a direct wire from the battery and the AC clutch worked - also the aircon is blowing cold air. I check the fuse under the hood and swap them over with the horn but still no luck. Appreciate any advise. |
There's a load protector on the compressor which also acts like a fuse, have you checked this?
Hi slowcrash - an aircon mechanic will check the car tomorrow. Since the ac worked on direct battery - I am hoping a re-gas will fix the problem :)
Thanks |
Turns out that there is no ac gas. No leak upon testing by a professional ac mechanic. Simple re-gas fixed the problem :)
Originally Posted by sohcy
(Post 24521671)
Where was the leak? |
Did they add die? Alot of times a leak will show after a couple weeks of running but die needs to be added.
