Another tranny issue
if im not mistaken, the reason people were using GM syncromech is worn trannys was because it had 'friction modifier' in it. from what i understand, the current formula of GMSM does not have this anymore and is not any better than running plain old honda MTF. is this correct?
Also try cleaning/lubing the slave under the car, and pull the fork out and grease/clean that as well. Make sure the clutch is adjusted properly (there are 2 adjustments I believe) 31k I find it hard to believe its from wear.
Let me ask you, does the shifter go into gear on a cold car?
The clutch pedal is adjusted properly, I made sure that it wasn't the issue. Even so I doubt it's the clutch because I have no problem putting it in 1st, 5th, 6th and reverse.
LOL, I actually tried double clutch up-shifting and it made no difference. I'm just confused because once the tranny is warmed up or after driving for a while the shifting becomes smoother even though I'm using Honda MTF.
